DSMLink and LM-1 with LMA-3
Dan-TSS
May 4, 2005
Portville, New York
I am waiting for the DSMLink to arrive, and am wanting to begin installing my Innovate LM-1/LMA-3. To do so, it would be easiest if I had the ecu pin-out wiring info. for these items on this '95 tsi talon:
-airflow meter signal
-rpm/tach signal
-knock signal
-TPS signal
*does anyone have quick access to this info./viewable online(I do not have a fsm) or can somebody please take a few seconds and post it up for me.....
**My search results led me to this link..but it isn't listing any specific models or years?...
http://www.taboospeedshop.com/wiring.htm
TIA
Dan
*Link me please?
I have been searching this site for weeks, finally broke down and signed in as a member to post this specific question....doing my best not to be an annoying newb!
Your help is appreciated/noted. :)
Dan
um, thanx? :notgood:
-I assume that you are posting the obvious link because you are not aware of the location of the information?
*I have been there searching all morning....no luck.
I hate to waste space, I am looking for a link to the information, as I have not found anything that is directly related to my question......the other piece of info. that would be helpful is if the wiring info. in the link I posted, does it apply to the '95 TSI?
Dan
I have DSMLink and the LM-1, you might want to wait on installing the LMA-3 until you get DSMLink.
DSMLink will log pretty much everything the LMA-3 can, I can't remember if it can log EGT's, but EGT's are useless if you can look at knock, injector duty cycle, and AFR.
I am ditching the LM-1 and getting a Zeitronix ZT-2, as it is smaller and easier to mount out of the way. The LM-1 works great, but it is too bulky to mount next to the ECU, plus I don't need a display to look at since DSMLink can log it.
IMO try to sell or return the LM-1/LMA-3 and get either a ZT-2, PLX, or Techedge. Also get a GM 3bar map sensor and you can log pretty much everything the LMA-3 will. Except of course all of the info would be in one, easy to read log.
Just giving you a heads up.
*Now we're talking...thanx!
I'm about to go through many more headaches...when the DSMLink gets here.
-I am assuming that tuning this in is going to be different than all my other experiences, figured the hardest part should be the tuning, not the install.
thank you again.
Dan :thumb:
thank you again.
Dan :thumb:
Tuning with it is a piece of cake. Get your global and dead time set, make a log to check for knock. Start removing fuel. Its cake :thumb:
*I'd suggest logging TPS, Knock, and MAP or MAS along with RPM with the LM-2.
The information on what the LM-2 can accept and how to deal with different types of inputs is located in the LM-2 users manual(downloadable from the innovate website).
-I have decided(in my application) to go ahead and use the LM-1 only and feed the analog output from the LM-1 to the dsmlink ecu(using an existing unused sensor input like MDP) for viewing logged info. on one screen.
Dan :cool:
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
