Bought A LM-1
mtwollet
180
Aug 7, 2004
Hello I Just Bought A LM-1 Yesterday, And This Afternoon I was going to get the bung welded in before the catalytic converter, the reason I bought it is because I was not passing emissions, Some of my questions are.
I was going to install the o2 sensor after the o2 housing but before the cat. should I worry about fabricating a copper heat sink for the sensor. Keep in mind this will just be used for part throttle tuning at around a target afr of 13.5-1 (part throttle).
I may not worry about WOT tuning at the moment since I just need to pass emissions.
am I pretty much on track with my approach. any suggestions.
I use an LM-1 and my bung is welded in right before my flex section. I don't have a heat shield and it works fine, it does not get too hot there. I also have the XM-1 guage, so my wideband 02 is in at all times, and always on. Its been on for a few months now and have no problems.
THX Dan :) Hopefully The Evil Goverment will grant me the privelage to pass emissions
I to use the LM1 and have it just before the flex well more the 90* heading back towards the cat. Same thing no heat sink and no probs.
Have you ever considered dsmlink? I'm positive i wouldn't have passed when i had my safc in my car. I put in my dsmlink, setup the default for 650cc injectors then took my car to get emissions. It passed with flying colors. I had the stock downpipe and cat on it, with the RSR catback remaining. After I passed the stock downpipe and cat came off.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
