LM-1 Wideband Install
mtwollet
180
Aug 7, 2004
My Question is I'll be shortly installing an lm-1 kit and want to use the downstream bung where the stock sensor goes to put the wideband sensor there. If I disconnect it and zip tie it up. with the harness disconnected there is no heater active on the sensor to melt the zip tie or catch fire. Does this sound ok.
What I was concerned with was I did'nt want the stock downstream o2 sensor active and hot just secured by zip ties, while I do wideband pulls.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
