dsmchip install now when i put car into ignition clicking all over!!
Laguna739
138
Oct 8, 2002
Loveland, Colorado
As i said, i got a dsmchip from dsmchips.com. got the clutch switch wired up and then pulled out ecu. opened it up, removed the chip using desauder?? (sp Sorr) wire and pulled the chip out. I put the dsmchip in and now when i go to start everything is clicking. can anyone gimme some ideas. i dont really know where to start... car will turn over but not start all accessories work. thanks tuners~!
I have never had your specific problem because I bought a used old school TMO Eprom ECU and the guy told me it worked...turns out it clicked every solenoid under the hood, and drove the injectors 100% when I turned the key on.
I think you need to contact Dave Mertz at DSMlink. His rates are great and he knows DSM ECU's.
Something like $66.00/hr in 10 minute intervals. He traced a few circuits on my 95 Eprom and found the problem and fixed it and charged me $44.00 for the ECU shipped back to me. He packed it very good in solid foam and I recieved it and installed it.....car cranked right up and runs great....:thumb:
Good luck man, its worth it!!
are you saying that you desoldered your stock EPROM yourself? Was this the frist thing you have ever desoldered? And you did put a socket in their correct? You did say. Their is a chance that you lifted a trace. Also the notch in the EPROM faces in on the ECU when you install it.
ive sodered lots of things in my lifetime, little while back i had an internet job of saudering xboxs so id like to think im not a complete noob. as to the in backwards you can bet your bottom dollar i'll check. (id also hope im not as dumb as that LOL but i guess you never know) thanks tuners! if you have any other ideas feel free to post em :thumb:
