ECMlink Car stalls when put into 1st gear
Bo0sTeD 4G63
468
79
Aug 31, 2008
Miami, Florida
1). Any boost, vac, or exhaust leaks? Boost leak tested 5psi above your max boost with no leaks?
No
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: NGK, 3 Months Old
Spark plug brand, type and Gap: NGK BPR7ES 0.28
5). Motor health (Compression Test)
Cylinder 1: 155
Cylinder 2: 155
Cylinder 3: 155
Cylinder 4: 155
6). Performed basic throttle body adjustments?
Idle Switch: No
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
8.5:1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 11.7-12.4
Car running: 13.4-14.1
11). Base fuel pressure and injector values
Base Fuel Pressure: 50 psi
Injector Size (cc/min): FIC Hi-Z 2150cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: AEM UEGO
Calibration Date: Last week
13). Type of fuel
Type: E85
Percent of Ethanol:
14). Watched ECMlink how-to videos?
Yes
The problem I am having is as soon as I press the brake and put the car in gear it stalls out. The car was previously tuned when it was FWD manual. I have recently converted it to AWD Automatic. I have attached a log with about 20 seconds of idle before I put it into gear. Any help will be greatly appreciated.
