VWnut8392
- 0
- Jan 9, 2010
latrobe,
Pennsylvania
I've been looking for other options for my VW in the ECU control department as the best thing factory wise for a boosted VW is digifant 1 and its so limited and locked down i find it useless anymore. VW guys are so greedy with giving out ECU secrets its crazy. anyhow im not the most wealthy guy and cannot afford a stand alone setup so i've been looking into using honda managment or DSM managment and i leaned to all you lucky DSM guys out there. im working on a 2.0 16V turbo engine consisting of a mix and match of factory VW parts, some cummins parts, some custom made and some aftermarket. i already have several of the DSM sensors from a 90 talon TSI including the throttle body, cam angle sensor, MAF, and the engine harness so far. i need to know if there are any others im missing that are necessary to make the engine run. i was going to save up and buy DSMlink V3 but i jsut recently found out about the EV8 ECU conversion for the 1G and was leaning toward that because its way cheaper than DSMlink. i've been studying the harness diagrams and it seems i may be able to use the factory VW coolant temp sensors, there is a vehicle speed signal at the cluster as my car has a cable driven speedo, wondering if the tach output from the ECU will read properly with the VW cluster, i had a friend machine an adapter to fit the cam angle sensor where the VW's distributor used to fit in the head. is there anything i am missing at the moment? i would like to be able to get away from using a MAF and just run atleast a GM 3.5 bar MAP sensor. its late and im tired im sure i'll think of more to ask you DSM wiring guru's. by the way i have a ton of hybrid VW swaps under my belt so im pretty good with wiring and related. any help would be great, as if this all goes well i've also been thinking of actually fabricating all the DSM engine and driveline into my GTI, but thats far down the road. here's a few pics of the car i plan on doing this to.
<a href="http://smg.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/?action=view¤t=100_0580.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/100_0580.jpg" border="0" alt="Photobucket"></a>
<a href="http://smg.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/?action=view¤t=000_0002.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/000_0002.jpg" border="0" alt="Photobucket"></a>
<a href="http://smg.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/?action=view¤t=Picture548.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/VWnut8392/montana%20green%20GTI/Picture548.jpg" border="0" alt="Photobucket"></a>
it has an G60 crossflow turbo in it right now running on digifant 1 with a T3T04E,custom log turbo manifold, audi 5000 wastegate externally dumping, custom intercooler piping thats 2 1/2 to the intercooler and 3in from the intercooler to the 3in VR6 throttle body, the intake is custom made 3in short runner with velocity stacks inside, 310cc injectors which are holding me at 15psi. i need 440's to run above that and using 450 DSM's is what birthed this whole idea actually.
this is just one of the many ideas i have, i own several other project cars as well. one is my lifted 86 golf that i plan on setting the body on an isuzu tracker frame and driveline powered with a VW turbo diesel engine, and i cant forget to include my mid engine jetta coupe but that project isnt started yet as im not finished with these two.
here's my lifted golf now
<a href="http://smg.photobucket.com/albums/v76/VWnut8392/monster%20golf/?action=view¤t=IMG_1151.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/VWnut8392/monster%20golf/IMG_1151.jpg" border="0" alt="Photobucket"></a>
<a href="http://smg.photobucket.com/albums/v76/VWnut8392/monster%20golf/?action=view¤t=IMG_1118.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v76/VWnut8392/monster%20golf/IMG_1118.jpg" border="0" alt="Photobucket"></a>
i hope i dont get criticized for what im doing, most of the VW community online has shunned me for this idea but if i was still going to waste my time cracking digifant 1 and tell them all about it that would be a different story. so please be cool. thanks.
.. I would rather go for the DSMlink but its your ball park.. WIth link you can change things and imitate things to make them work.. You could also run speed density with a simple map and iat...
