dsm link 2/step /stutter box pin out evo8 swap
hediki12
346
Oct 13, 2008
mt vernon, New York
hey i just got my car it had dsm link in there and im throwing in a evo 8 all pins are changed except that one. because i have no clue which is the dsm link stutter box cable. do you now what pin number it goes to? or what it swaps/shares with??? thanks!
just off the top of my head i think it is pin 58. but let me check. does dsmlink's 2 step cable have anything special involved in it or is it just a straight wire from the cruse switch to the ecu?
correction, 58 is the tacho.
clutch switch goes to pin 43.
i know it goes to 43 on the evo 8 ecu ive done it before just have no clue on where it goes in dsmlink i doubt its the same? maybe....maybe not ill double check... none of the pdf on there site works so thats why...:banghead::banghead:
ok i got it now the previous owner has it on the upper clutch switch!! LOL. so yea ima resplice 2 day.
Im confused here.. Are you running dsmlink with an evo8 ecu or are you putting in a evo 8 ecu into your already dsmlinked car. Or are you putting a 2g ecu into an evo so you can run dsmlink??? You can't run link and an evo8 ecu unless I'm so far behind the ecmlink updates.....
LOL the car had link but seller kept it and im using my evio 8 ecu in it. sry i typed that from my phone i was at work and didnt wanna get caught
had to reinstall adobe pdf...
Might I ask why you are pulling DSM Link out of the car and putting the Evo8 Ecu in? I am somewhat familiar with the capabilities of both, and from what I Understand Link is easier to use for the average user.
Well the previous owner pulled it out. not him.. Sorry about the confusion and good luck on your evo 8 swap
LOL yea. i was looking at it seems like there is no splice. my friend who had a few dsms with link in it says you dont have to wire in the 2 step you just have to wire in the nlts. so i shouldn't worry about the pins.
That is correct. The 2 step is built in, but the clutch cut wire has to be installed just for the NLTS.
  • Wanted 6 bolt NT water pipe
    • chrisman287
