2 step using DSMCHIP
ali
342
Sep 20, 2006
Lincoln, Nebraska
Ok I am having problems wiring up my 2-step, first I did cut the black wire pin104 and wired it up to my safety clutch switch. Now the problem I have is that from what I have been told I have to disable my safety switch or put i diode in between. Does that sound right? If yes I do I disable my clutch safety switch but still be able to use it for 2-step?
Thanks
Ali
You stutterbox should work regardless. I think Jeff uses the code for the VSS to tell if the car is moving or not. If you are having problems with the stutterbox then it's probably a problem with your VSS. Now, if the stutterbox is working but your NLTS is not, that is when your clutch wire comes in and tells your ECU when the clutch is depressed while the car is moving it goes to the NLTS rev limit.
Does your logger ever show a code for the VSS?
