drum brakes inside of rear rotor WTF!!!
Psi'dGS-T
110
Jan 19, 2004
fremont, California
OK so i just went to replace my rear rotors and pads, and when i pull off the rotors inside there is a drum brake set up. I figured out this was the E-brake, is this normal on 2g's? I've never seen this before. Also the passanger rear is making a light grinding/squeling noise when i drive it. I figure that maybe i need to push the piston back in a little farther, what do you think?Thanks in advance guys!!
Umm pushing the piston in isn't gonna do anything. It's just gonna come back out when you hit the brakes.
I said the same thing when I found that in the rear WTF????? Its the E- brake set up. It completely normal. Those brakes will never wear out. The adjustment for the E-brake is in the center console. Its a bolt connected to the cable. Maybe adjust it to have more slack on ther cable.
Did you put _all_ the little clips, shims and doodads back on the pads?
Yeah everything is back on, i'll check twice to be sure. With just the rotor on, i'll spin it and there is no grinding, so i know it's not the e-brake shoes. Once i bolt the caliper on and try to spin it then the grinding happens.The grinding is just on the passanger side.I'll go over everything again, and see what happens.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
