Driving without a Subframe bolt?
hypergenesis
886
Oct 21, 2010
Tracy, California
While I was doing my clutch I was taking off teh lower subframe/crossmember bolt connected to the radiator supports and had the bolt break inside. I already replaced teh entire clutch and now I was wondering is it same to drive on until I take it to get fixed?
Thanks
Armin
If its seized well enough it could work to your advantage: the rust/seized metal could hold the subframe along with the metal bumper threads.
If theres movement on the subframe bar I would try to get it fixed asap... the other motor mounts will hold the engine weight just fine I'm sure but I would rather not have that last bolt snap on a pothole.
