driving the lights went dim. and the turbo timer said 10.5 volts
talontedtsi1995
140
Sep 14, 2005
reading, Pennsylvania
I have a 96 talon tsi and it started to act funny..out of no where when driving the lights went dim. and the turbo timer said 10.5 volts instead of the usual 14.3..so I drove the car home, shut it off, the lights would not turn off the windows wouldn't go up. Got the lights off after whiles, then the car would start but have low volts and the windows still wouldnt go up, go a new batt. and windows went up but still runs low volts with everything dim at 11 volts, what could be wrong? the car started and runs but wont hold enough volts? could it be the alt.? started? cables? The alt. is alreayd about a year old.. let me know thanks!
i agree, get your alternator checked out 1st. while its off, check your ALT pulley and make sure its not damaged and it spins rather easy. reset your ecu while your at it.
check your alternator....get a voltmeter and check the voltage at the battery before and after turning the car on. Without the car on you should have 12 volts when the car is running you should have around 14. Also check to see if the alternator belt is slipping causing the altenator not to generate the voltage. Check all fuses and grounds. Autozone should check your charging system for free.
  • Wanted NA 1ga running and driving
    I'm in the market for a N/A 1ga Dsm preferably running and driving that's manual. no preference...
    • Nii
  • For sale 2g 7 bolt engine build parts and mounts,
    New lowered prices on everything!
    • beegeezy
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
