Car wont start and lights dim
DSM BoosT
150
May 5, 2009
hudson, New Hampshire
Okay So I got car to crank by hand, cylinders in the right position and the timing is perfect. So I go to start it and it doesn't start ill put a video up. I checked to make sure injectors were firing, they are and the spark plugs are getting gas. But when I try to turn the car on the lights dim and it wont run, (bad alternator???) I even try to jump it but it wont start. If it help I just installed a new water pump don't know if that would have anything to do with it but anyway and when I did that I cut the belt for the ac and took the one pulley out for it. help?? could it be a stupid sensor or something? ask me stuff if i have seen it or already tested for it to start the process of elimination
turn volume up on video so you can hear it
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid75.photobucket.com/albums/i294/VVeaver17/DIMLIGHT.flv">
Hope that fixes your problem but once again I dont believe that it is the starter or the battery. Make sure you follow toke specs on that head and keep us updated.
  • Wanted 6 bolt NT water pipe
    • chrisman287
