drivetrain conversion newb question?
nocturnal_tsi
Aug 7, 2016
GORDON, Georgia
the first pic is the motor in my car (obviously) then the other is the one out of my 5speed donor... the auto doesnt have a line up pin where the maunual does?!?! do i need to swap these out? im talking about the 7 bolt piece in the middle that might help LOL
I don't have experience with DSM auto trans/crankshafts, but so long as you have enough room for the trans input shaft to spline mesh with your clutch, even with the auto crank, you should be fine. The input shaft won't move in and out so I say test fit the trans to the engine without the clutch attached, but with the flywheel installed. If there's nothing keeping it from bolting up properly, you're good to go.
thanks for the replys! i was able to get it out fairly easy with a small pry bar... but im still wondering do i need the line up pin or will ibe fine without it?
