2G Drive axle will not budge
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
So I'm trying to remove the left drive axel out of my 2g automatic 420a and the axle will not for whatever reason budge and move out of the hub. I've tried everything. Pb blaster, I've hammered the axle with a sledgehammer for a long time. It just will not budge from the hub. I even ended up cutting the axle because I have a spare. What should I do? Heat around the hub? Replace entire hub assembly? It just won't even move, I've never seen anything like this. Please help!
Make sure you use some antisieze when you put it back together LOL. Access to air tools? Maybe air hammer? A little bit of heat does go a long ways. Doesn't hurt to try!
Yeah I'm probably gonna go with heat, it's crazy how seized up this axle is. I beat it with a hammer so hard it started to bend the bolt a little.
The best sold penetrating oil is KROIL which ive used for years with really good luck. Ive been experimenting with a mixture of atf and acetone which has been tested to be the best penetrating oil. You can make a puller out of a donut. You would need to weld a plate (1/2") to the face of the donut that is threaded in the center, put some all thread (1/2-13 at least) thru the hole with a nut welded on the end to drive the all thread. The plate will need to be drilled or cut to clear the wheel studs.
A buddy built a puller like this, used heat, spent about a week working on it and was unable to get the axle out. He separated the cv, pulled the motor, and when he put the motor back in put the cv together under the car. I antiseized my axles 12 years ago and drive the car especially in winter, I can take the axle nuts off and push the cv's thru by hand.
I would take the whole spindle out with the axle and then place it somewhere where it will stay upright and soak the hell out of it with penetrating oil .
I have never seen anybody get the axle out of the hub splines when they are frozen like that. I've seen people use heat, presses, etc and have not removed the shaft. Most shops just replace the entire knuckle....lots of money. If you can get to the 4 bolts on the back of the hub, you should be able to remove the hub and axle, saving everything else.
