downpipe
Dido... Don't shop for anything 4g63 if you have an N/A car. Pacesetter makes a decent piece for very low cost on your car.
If you have some fabrication skills you can technically use that DP, but it has to be flipped, then the part going up has to be cut off and re-welded 180*. I did it to mine for my turbo, works great, but again, does take time.
If n/t, just buy the header kit and you'll be good. Connects up to stock cat
what we have is called a flex pipe virtually does the same thing except the flanges wont match up because our exhaust manifold is different from the turbo flange just make sure what ever you buy is for a rs or gs or a 420a
