Downpipe
D3monX
263
Jul 3, 2007
Fredericksburg, Virginia
yeah i was wondering if someone knew where i can get a downpipe for this turbo...i bought a flange but i was wonderiing if someoen knew a site i can just buy it off of for my 99 gs
does anyone know the dimesions for it..or will i have to tow it there with the turbo kit installed
The problem with making a downpipe for an eclipse... is the specs on every vehicle are differen't. So someone else's down pipe wont work for my car. Unless its the exact same setup. It all depends on how the exhaust side of the turbo is clocked on the manifold... If you ask for a dp for that turbo... you could get one that would send the exhaust in the air, or into the engine, or into your radiator.
what would u recomend on me doing for get the exhaust shop to make my down pipe when the turbo on...should i just tow it there or drive it there for that little period of time
I'd suggest you tow it unless, you want to risk melting some hoses. Take the flange with and tell them you want a down pipe made from the turbo to where ever you want it to hook up. If it's an external wastegate, you'll need a flange for that to. Depending on the shop, you might need the bolts that are going to hold you downpipe and wastegate.
Have them use Mandrel bends as well when they fab up a downpipe. Ask before bringing it there if they have the proper bends. If not, summit is your friend.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
