Dowel Pins ( How many needed)
LIST OF DOWEL PINS ON A 4G63 ENGINE
1 dowel pin is on the crank to position the flywheel
3 dowel pins are on the flywheel to position the pressure plate
2 dowel pins for the transmission to engine block
2 dowel pins for the rear case seal to block
2 dowel pins for the head to block
2 dowel pins for the front case (oil pump)
1 dowel pin on each cam to position the gears
24 dowel pins for the cam caps
Im not shure if Im forgetting any of them or not but Im shure I got all of them. I hope that helps you out on getting what you need.
