door sag need help!!!
the door sags it drops like 2 inches when you open it so you got to lift it up then close it for it to shut i was wondering if their is a clip or washer in the interior (under the panel) i can replace for it to stop ive put 3 differnt hinges on it already last set was new so whey is it sagging?
I know it doesnt sound like the best advice, but my door used to sag a little, until I got pissed one day, and pulled the door up as hard as I can. Fit like a glove.
This really made me lauph when i saw this... my car has been sitting for a few months and i ran into the same problem... i opened the door and it sagged about an inch or so and i had to roll down the window, lift up on the handle and then i was able to get it to latch... This worked out fine for a week or so until i almost lost my door because it poped open while driving... I went to a body shop by my house and they told me 2500 bucks to fix it! being the DSM do it yourselfer i fixed the problem myself. I JUST DID THIS LAST WEEK!
1st off check the hinges.. i opened my door all the way and had my friend lift up and down on the door. While he was doing this i saw that the bottom hinge was moving.
Next i went under the drivers side dashboard, removed the kick panel right under the fuse box and that leads right into the back of the lower door hinge. I saw that when he moved the door up and down the bottom bolts were moving. ( What it is is a bolt welded into the body which on my car rusted out and wasnt holding any weight anymore )
Knowing what the problem was, i decided to fix it. I made cardboard shims to support the door in a perfect place aligned with the door latch. ( i placed them on the door stills on the inside of the car body ) Once i was happy with the fitment i removed the 2 rusted out bolts.
I took a 3/8 drill bit and drilled out the rusted nuts. I then installed stainless 3/8 bolts into the body and used fender washers on the inside for support. ( fender washers can be bought at any car quest, all they are is very large diameter washers. ) i tightened it all up and put some lock tight on the nuts and the job was done.
Once the shims were removed i tested the door. It didnt sag at all, and the door closes and opens like new. I hope this has been some help you i turned a 2500 job into about 3 hours of work and 3 dollars worth of bolts, nuts, and washers. If you have any questions let me know ill try and explain myself better. Good luck.
Ouch, just to do some minor welding, local shop ran me $75 bucks good as new. Check hinge's that's where the problem starts at, and it is common. Another note, dont let people rest on your open doors :thumb:
thanks i gotta try that and yea rolling down the window and picking it up caused my door handle to break LOL so now i just climb through the window
Is this the car that's on columbus craigslist for 5 G's? Better fix that door before you sell it for that much :thumb:
Hope you get it worked out.
