Door harness Help
xterminat0r
35
10
Feb 4, 2016
Inver Grove Heights, Minnesota
I got a junk yard door and it's off a convertible. The car I own is not a convertible. They are both power windows and locks. My harness is smaller so it has half the wires. My harness has one green/yellow wire and the convertible door does not. What wire do I splice into?
are you using the spyder window switch and door panel?
the (green/yellow) goes to PIN30 (blue/yellow) on the spyder harness main plug
on the spyder harness main plug you won't be using:
PIN8 red
PIN9 (red/black)
PIN 20 (red/white)
PIN 21 (red/blue)
PIN 22 (black/white)
The wiring I had was correct the motor in the driver junkyard door is dead. Took me a few hours to figure that out.
PIN8 red
PIN9 (red/black)
PIN 20 (red/white)
PIN 21 (red/blue)
The wires I listed are the ones for the operation of the rear windows. Since your rearr window dont roll down, there isnt a wire on your existing harness to splice them into
