Texas gst
- 225
- 0
- Oct 17, 2010
Lubbock,
Texas
Please help!! I just got a 95 gst from a "have no idea" person that got it in a trade. I will attach some pics so hopefully it makes sense. I'm not sure vac. lines are right. It has an M10 Garrett turbo .48 in .49 out (I know nothing about turbo's). When I got the car, it was maxing out the boost gauge (20 plus) and the nipple on the inlet housing in the first photo (pointing at it) had nothing hooked up to it, and neither did the top nipple on the second photo (kind of hard to see as it is under the air inlet housing). I think it's the waste gate solenoid? I hooked these together and was running like 12 pounds of boost. I was told it needed a pressure line hooked to the solenoid so I plugged the one on the air inlet and tee-d a line that was going to the bov (photo 3, now plugged off). I was then told that I should not tee off the bov line. Today I plugged that line (photo 3 again) and hooked a line back up from solenoid to air inlet. When I drove home it was peaking at 20 plus boost again. Hope this makes sense. The last picture is just showing where my boost gauge (cheap Sunpro already on it) is getting readings. I hope someone can set me straight so I don't trash it. I kinda doubt this turbo can push 20-25 pounds of boost so I really need help please. It smells kind of like it's running rich also and the plugs indicate that as well. Not REAL rich but not quite right. And another note, my shifter is REALLY, Really loose, any thoughts there? It's hard to find first it's so loose.
. do a search on it and see if you can come up with safe boost levels and such. hope this helps!
