l3igl3ang
- 539
- 2
- Aug 10, 2005
ft smith,
Arkansas
Yeah after finely get the swap done and motor running good the godd**m transmission wont go into great now
its just grinds and we have bleed the system to get the air out and still no go. When we press the clutch it has some play in it then it gets hard the futer we go torge the floor. If there any way to adjust it so it pushs the rod futher in? The transmission worked fine before the swap but had a lighter duty clutch in it and i replaced it with a statge 2 clutch and a presure plate and also a new flywheel but its a OEM flywheel nothing fancy.
