Do I need to remove the center nut on rotor, to remove rotor?
toicy4ya
108
Jun 9, 2005
Bronx, New York
Brake calipers aside, in order to remove the front rotors on a 99 eclipse gs spyder do I need to remove that center nut with the pin in order to remove the rotor?
Thanks
Hahah just tap it with a mallet. If you live in a state that uses salt be prepared for some fun or wrecking some stuff getting them off unless you get lucky. We tried to beat one off my car with an 8lb sledge (it came to that) we tried everything else and ended up beating it with that and wrecking the rotor. we were changing it anyways. B ut yeah it can get hard to get them off if they are really rusted on.
hmmm...... My car has been a Great Lakes car it's entire life (LOTS of salt due to harsh winters). Granted, I have never driven it in the winter, but it's previous owner did. When I changed out the original rotors 2 months ago, 2 of them just slid right off, and the other 2 only took one small tap with the rubber mallet. IDK, maybe I was just lucky; I did all new pads and rotors in exactly 70 min from start to finish. :rocks:
your car is "only" 6 years old though hehe
my rotors are a solid hunk of rust :notgood:
Ya, I just ended up doing my front and rear brakes. The rears came off by using bolts in the little helper holes, but the fronts... that was a different story.
PB Blaster from behind the rotor right where it meets the hub, spin it around to make sure it soaks in, tap on the inner part of the rotor where the lug studs are to help break it free, then try the helper holes.
In my case, the helper holes stripped out quickly and BFH it was.
Still not horribly difficult, just a PITA... guess thats what I get for having the stock brake rotors until 104K miles? :)
good luck,
-Chris
