Do I need a thicker headgasket???
91orangeGST
193
May 25, 2004
Winfield, Missouri
I just got my head milled down 30/1000 of an inch and I was wondering if I neededa thicker head gasket than stock. Also what is the distance between the valves and the piston head at their closes point? 91 4G63T
Kyle,
might think about asking this question in tech forums, not many noobies would know the answer to that question, LOL i sure don't and i sure as hell dont want to guess.
If the headgasket is normal size and the head was milled then the valves can hit the pistons and thta is a BIG problem!
You wont run into piston to valve issues with .030 milled off the head only and none on the block.If you are running after market cams then I would look into it further but if your stock you will be fine. I would just run the stock oem HG with ARP studs torqued to 75-80 lbs and be done with it. Make sure the head and block surfaces are very clean for best possible seal and gasket life.
