do i need a separate kit to install 14b turbo?
Big B
99
May 5, 2011
atlanta, Georgia
hey im looking to install a 14b turbo on my eclipse. do i need a separate kit to install the turbo im buying online or is it just like an even swap out? and if not what would be a good kit to get?
I just use the 1g j pipe, and connect the upper part of the 1g lower intercooler pipe to the lower 2g pipe with a 2-2.5 exhaust adaptor. It actually fits pretty well.
Does the 14b that you are buying not come with coolant and oil lines? If not than i would fine one that does. The installs kit is just oil lines, coolant lines, banjo bolts crush washers, gaskets, and a j pipe.
  • Wanted 6 bolt NT water pipe
    • chrisman287
