Do I install 1g cas after or before degreeing cams?
954g63gst
228
24
May 24, 2012
gardner, Massachusetts
I am about to finish my build and I want to know if I should wait on installing the 1g cas till after I degree my new cams. Because if I install the cas then advance or retard my intake cam, wont that mess up ignition timing. Were as if I got everything timed correctly then installed the cas. Then timing will only need minor to no adjusting. Am I correct or not. Sorry I just worry my self sometimes.
After Degreeing your cams you pull out the old ass timing light and make sure your CAS is Dead on time.
