do i have big 16g???
90_laser_rs
32
Nov 16, 2009
platte city, Missouri
ok guys back once again. Big mofo problem i am very certain that i got bunked LOL. just bought my very first dsm about month and a half ago said it had a b16g the numbers on the hot side are 49n5s26nh2. and on the cold it just says
<w L> i think i got ebay pos but car rus strong no boost leaks would like to know what turbo is on it i think ....t25 from 2g but doubtful turbo is big....help!:confused:
From what I've been told, a 16g turbo will have a A set of big blades and a smaller set between them. The stock turbo will have equal length blades. Hope this helps. Thats the way I've always been able to tell.
i will take off the intake boot tomorrow. from what i have reseached it dosnt seem to be no number on the cold/good looking side :cry: whats a good site to pick one up if it is not???
Then it's obviously not a 16g variant or a 14b.
http://i5.tinypic.com/20k23x3.jpg
Where does the intercooler pipe connect to the compressor housing at? Is there some sort of j-pipe off the compressor? You say it is "BIG", but does it utilize a bolton mitsu exhaust housing or are you running some sort of non-mitsu flanged manifold? ...just to clarify it says absolutely nothing on the compressor cover?
Here is a t-25 off a 2g.
http://www.gpopshop.com/t25web.jpg
intercooler pipe at the bottom of the turbo right off the boost side/or the side with the intake to it and on that same side on the turbo it says this
just like this.....w l....same to a t.....it has a 2gtb and a 1g header....sorry for this confusion by the way i just have a side mount not a front just have hard pipes to it if that helps....???? and yeah its not a t 25 and no its not scrapped down or anything....
just like this.....<W L>....same to a t.....it has a 2gtb and a 1g header....sorry for this confusion by the way i just have a side mount not a front just have hard pipes to it if that helps....???? and yeah its not a t 25 and no its not scrapped down or anything....
SO it does say TDO5H on the compressor cover (you said it says this...............just like this..............same to a T)? You're confusing the sh!t out of me. :ohdamn: Use complete sentences, grammar, and punctuation please.
Post up a full pic, it will be a lot easier to answer.
will try lost cam charger....will be tomorrow.
Sorry... ok all it says is WL. That is all do you want the numbers on the hot side?
yea he texted me about this earlier im completly stumped trying to figure out what kinda turbo that is..i sold that car to another guy with a ginuine big 16g which had the 014-20 serial with a big 42 etched in it..but im guessing the douchebag he got the car from ####ed him over and took that one off and put some off brand turbo on it.he says it dont have td05h on it so i know for a fact its not the same turbo that was on there when i sold it to the other guy...oh and he says it has braded oil lines if that help any..he said the guy had like 8 2gs sitting around in the shop so im guessing the guy swapped a stock t25 in there
Noob question... So if a 49178-05200 is a Small 16g, then what is this one?
Yea, could be, but see that 2nd to last "0"...is it just me or is that a 2? So would it then be 49179-52020?
:edit:
Or maybe I am just looking at it wrong.
FIXED.
Yeah, you are seeing it right. Its a blank spot that they etch the number into. There's a 2 there: 49179-52020
A FP DSM Green (Garrett 50-trim compressor, TD06H turbine).
You can't always trust the part number on the compressor cover.
