DNP T4 manifold and GT35R turbo??
11sec_GSX
73
Jul 23, 2004
Milwaukee, Wisconsin
Did anyone have a clearance issue with the oil feed line being right under the brace? Unless I use a banjo-fitting there is not enough clearance for a normal fitting and a 90 degree hose-end, and they don't make 90 degree fittings for the GT ball-bearings. I see ATP Turbo has a special "low-profile" banjo-fitting for the GT turbo's and I might have to go with that...??????????:confused: Just wondering if anybody else has had or heard about this issue?
the banjo fitting will work just fine.
I had no problems with the oil feed on my SC6181SP or my GT40R with the DNP T4 manifold (bolt on feed plate with 90 degree to -4AN feed line)
    • george bromwell
    • pma1123
    • Sdcryan1
