DIY: $25 Leakdown Tester
dsmzoom
614
Sep 4, 2007
West Islip, New York
I made this leakdown tester off the top of my head at lowes using some other methods I found online. Works effectively and for twenty five dollars you cant beat it. I found all the materials I would need at Lowes so you shouldn't have any trouble at a local hardware store.
Materials:
Mini Air Pressure Regulator
Pressure Gauge 0-100psi (mine came with the regulator)
12" grease gun hose
1/4"-1/8" Reducer
Quick Disconnect Fittings
Teflon Tape
Spark Plug Adapter
Pretty straight forward on assembly. The only tricky part was finding a spark plug adapter, some say to knock off the porcelain off an old spark plug and drill the guts out. Fortunately for me I had an extra adapter from my compression tester. If your as lucky as me, I just used a center punch to knock out the air valve in the adapter and you now have a leakdown tester adapter.
