greekgodchaos
- 565
- 212
- Jul 4, 2007
Vancouver,
Washington
Hot&Dry
Cyl1: 110
Cyl2: 110
Cyl3: 125
Cyl4: 125
Hot&Wet (Oil added)
Cyl1: 132
Cyl2: 133
Cyl3: 128
Cyl4: 133
Gapped plugs to: 0.029
Leakdown Results:
Cyl1: 60% Leak to Cyl2
Cyl2: 61% Leak to Cyl1
Cyl3: 65% Leak to Cyl4
Cyl4: 60% Leak to Cyl3
*An Ultrasonic Leak Detector was used to pinpoint where the air leaks were located.
*A U.S. General (Harbor Freight) Leakdown Tester was used for...well, the Leakdown Test.
*There is no blue or white smoke coming from my exhaust. Unless I push almost 18psi then white smoke comes out.
*No oil in the coolant.
*No coolant in the oil.
...Ideas?
UPDATE: I spaced that Cyl2 was probably on its Exhaust TDC so I cranked it again and retested 1 and 2. No leaking out of the valves, just between Cylinders.
Cyl1: 110
Cyl2: 110
Cyl3: 125
Cyl4: 125
Hot&Wet (Oil added)
Cyl1: 132
Cyl2: 133
Cyl3: 128
Cyl4: 133
Leakdown Results:
...Ideas?
