Discussion on engine "torque" misnomer
kenamond
DSM Wiseman
3,225
67
Feb 15, 2006
Los Alamos, New Mexico
Maybe this belongs in a different forum. Moderators feel free to move it.
I have to admit that I've been utterly confused by engine torque talk and how it relates to power since I was in college as a mechanical engineering student. Nobody explained it to me properly, and it is my suspicion that many describe it incorrectly all over the place (I found 4 references online in the past week, and all had it wrong).
I'm thinking I'm correct in what I'm about to say, but I tend to find out just how wrong I am by pounding my righteous chest on these forums. All I want out of this thread is a discussion of engine torque and a consensus in the end of what it's all about.
I'll start by stating some facts about work, energy, and power. I say they are facts, because they are straight out of the physics world. I've chosen my own wording just to keep it in context for this discussion.
Work and Energy
Work is the amount of energy that is expended in moving something against its will. By this, I mean that you have to apply a force to something and move it in the direction of that force. It is the amount of energy that is required to do something.
Example #1: Lifting a sack of potatoes from the floor to the back of a pickup truck. You have to apply a force away from the ground *and* move the sack of potatoes a few feet away from the ground.
Example #2: Compression/expansion of a gas. Assume you have a piston and cylinder full of gas. You have to apply force to the piston to decrease the volume of the gas in the cylinder. The physics geeks out there call this "PdV work", as you have to apply a pressure P to a fluid and change its volume some amount dV. Keep in mind that the gas can apply a pressure to its surroundings and increase its volume - but that's also PdV work. Obviously, we see the former case of work during the compression stroke of a 4-stroke engine. We smash the gas in the cylinder into an ever-decreasing volume by pushing on a piston. We also see the latter case of work during the power stroke. Gas at high pressure pushes the piston down which results in an increase of the volume of the gas. The compression stroke requires the engine to do work on the gas (compress the air/fuel mix) while the power stroke requires the combustion gas to do work on the engine (move the piston).
The units of work are the same as the units of energy. They are force*distance such as ft-lb or N-m. I'll get into this more later, but just because this is also the same units as torque, IT'S NOT THE SAME THING! That's where I was misled.
If you do the math for PdV work, you have pressure*volume. Pressure has units of force/area which is force/(length*length) or force/(length^2) like lb/in^2 or psi. Volume has units of length*length*length or in^3 or cubic inches. So if you multiply pressure and volume, you still get units of force*length.
Power
Power is the rate at which work is done. It is a work-rate. The units of power break down into force*distance/time like ft-lb/s or N-m/s. Notice that it is work per unit time or work/time. It states how quickly you can do work.
Lifting a sack of potatoes is another perfect example:
I can lift a whole 60-lb sack of potatoes in about 1 second from the ground to the bed of my pickup truck. The work is force*distance, so for a 60lb sack and a 3 foot lift, that works out to 180 ft-lb of work required to complete that task. The power is work/time. I did it in 1 second, so that's 180ft-lb/s of power.
Now, my 2 year old son can lift the sack of potatoes as well, but he'd probably do it two potatoes at a time with the help of a stool. He'd eventually do 180ft-lb of work to get the whole sack in the back of my truck, too. So we'd both do the exact same amount of work. But it may take him 60 seconds to do so. So my son is only generating 3ft-lb/s of power.
Pulleys, leverage, and hydraulics are all examples of this. The same amount of work is done in each case, but it takes longer. A 10:1 lever can lift 10x as much, but it does so 10x slower. The work is the same, but the power required is 1/10th as much.
Horsepower is a specific unit of power just like a foot is a unit of length. The definition of a horsepower is 33,000 ft-lb/min. A 1hp motor can lift 33,000 pounds up a height of one foot in one minute.
Work not Torque
Torque in the traditional sense is a twisting force. It is measured in units of force*length just as work and energy are, but that's where the similarities end.
Work requires you to apply a force and move something in the direction of that force. You can apply 100ft-lb of torque to a bolt without the bolt budging. That works out to exactly zero work done by you on the bolt. A ton of bricks sitting on the ground does no work either; even though it's pushing on the ground with 2000 pounds, it's not sinking, so no work is being done. If you apply 100ft-lb of torque to a bolt using a 4-foot breaker bar and rotate the bolt 90* in the process, you did work: you applied force to something (the handle of the breaker bar) and moved it (rotated it 90*). However, the work you did on that bolt was not 100ft-lb!!
The actual work done is the force applied to the breaker bar times the distance the breaker bar moved. If you were applying 100ft-lb of torque to a 4-foot breaker bar, then you were pushing on the bar with 25lb (25lb * 4feet = 100ft-lb of torque). The distance the handle of the bar moved to make that 90* turn is 1/4 of the circumference of a 8-foot diameter circle. The math works out to 6.28 feet. Taking the force of 25lb and the distance of 6.28 feet, that works out to 157 ft-lb of work...NOT 100ft-lb. Torque and work are not the same.
Work and Power and Engines
So how does this all fit together?
What everyone calls "torque" for engine performance is actually the work that is produced by the engine in one revolution. Since we're dealing with 4-stroke engines which only fire every other revolution, you could think of this as the average work done per revolution - half the work done in two revolutions or 1/20th the work done in 20 revolutions.
If we think about what goes on in the engine, there's a lot of work that the engine has to use to drive itself, and this work never makes it to the flywheel or the wheels:
- The compression stroke requires the engine to use some of its energy to compress the air/fuel mixture (and do PdV work on the air/fuel gas). It uses the work produced by other cylinders during their power strokes and the kinetic energy (think inertia) of all of the rotating and reciprocating mass in the engine to make it through the compression strokes of the different cylinders. The energy of the battery is used to get it all going in the first place when the motor is first started.
- Also, it takes energy to suck the intake charge into the cylinders and to expel the exhaust gasses during the exhaust stroke.
- And it takes energy to drive the turbine/compressor wheels. The turbocharger is actually a turbine engine in and of itself that is doing all 4 strokes at the same time. The turbine is driven by high-pressure exhaust gasses which cause it to turn (like the power stroke). This turning drives the compressor at the same time (compression stroke). Since the air is continuously feeding through both wheels, the intake and exhaust strokes are happening all the time. But the high pressure exhaust gasses which generate power in the turbocharger are produced during the exhaust stroke of the engine - and that is more work that the engine uses to make itself function and which doesn't make it to the flywheel or wheels. The piston has to work harder to push the exhaust out of the cylinder, because of the increased energy demand of the turbine.
- Then you have all of the friction and viscous losses, losses of energy via heat conduction into the coolant (from the block) and intercooler (from the hot compressor output), and vibrations (sound) which all leave the system and do not contribute to turning the flywheel or wheels.
The laws of thermodynamics state that energy is neither created nor destroyed. The only energy source in our engine is the combustion of the fuel-air mixture, and the trick is to get as much of that energy to the wheels.
Unless something has gone really wrong, even after all of these losses, we end up with work making it to the flywheel (analagous to brake horsepower) and to the wheels (analagous to wheel horsepower), although there are even more energy losses between the flywheel and road.
We can measure the power and/or energy (I refuse to call it torque) output of an engine at either the flywheel or at the wheels, and this is strictly controlled by where you actually measure it. You CANNOT back out power at the flywheel from power at the wheels, but I'm not going to go there in this discussion. If you bolt the engine up to an engine dyno, you'll get flywheel numbers. If you use a rolling road dyno, you'll get wheel numbers.
Regardless, the "torque" numbers are the amount of energy that the engine produced that actually made it to the measuring point (flywheel or wheels) PER REVOLUTION. In order for this to be useful, we need to know what RPM that "torque" value was measured. There are two reasons for this: 1) you need to know RPM to compute power and 2) engines produce different "torque" at different RPMs.
As for 1) above - since power is just the rate at which work is done, and the "torque" numbers are the work per revolution, we can compute power from (work per rev)*(rev per minute). There are some conversion factors to get it to horsepower, but that's the basic rule. As for the conversion factors, I already stated that 1hp=33000ft-lb/min. Also, 1rev=2*pi radians. A revolution is a dimension. It can be converted to a dimensionless value by converting to "radians". So putting all of this together to get power (in hp) in terms of rpm (in rev/min) and torque (in ft-lb), we get P=T*rpm/5252. But keep in mind that it's just taking the energy output from one revolution (that infamous "torque" number) and using the rpm to get the energy production rate of the engine.
As for 2) above - An engine running at 1rpm is NOT going to produce any work. It will stall. Our turbocharged motors aren't going to produce much work per rev at 1000rpm either. If you look at a dyno sheet, the most important number on it is probably peak "torque". That's the point in the rpm spectrum where the engine is producing the most energy per cycle. It's the engine's "sweet spot". In our engines, it's where everything is working best together. Turbo is at full boost, timing advance is good, intake and exhaust can handle the flow, cam timing is good for the current flow, etc. If you go a bit higher or lower, the energy production per rev drops off a bit; the engine is not quite as effective at producing energy per cycle. However, if your "torque" doesn't drop off very much past the peak "torque" value (at higher rpm than the peak "torque"), you can still get higher power at higher rpm. Since power is "torque"*rpm and the torque is holding in there as the rpm go higher, the power can continue to go up. Keep in mind, though, that the engine is doing a poorer job of generating energy.
Summary
What folks call torque is actually the energy produced per rev of a motor. It has nothing to do with twisting force other than the units are the same. High torque numbers mean that your engine is producing more energy per rev than low torque numbers. Since engines run differently at different rpm, the torque curves for an engine change with rpm. The torque curve is a bunch of snapshots of engine energy production capability at various engine speeds. Engines typically have a peak torque at a specific rpm, and this is where the engine is producing the most energy per rev than any other point in the curve.
Power is the rate of energy production of the engine. It is important, because it indicates how quickly energy can be produced from an engine. Lifting a 60lb sack of potatoes 3 feet is a fixed amount of work. Doing it in 1 second is better than doing it in 60 seconds. That's the difference between work (torque) and work rate (power).
Power in an engine is just torque*rpm, so it also varies as rpm changes (torque changes with rpm and (obviously) rpm changes with rpm). Peak power usually occurs at a higher rpm than peak torque, because rpm increases faster than torque drops off (usually), so the product of torque and rpm continues to go up a little while after the torque peak.
Nowhere am I saying power is not important. Let's say you have a motor with a peak torque of 300ft-lb at 5k rpm. It drops off after that, but still holds at 200ft-lb at 17k rpm if your engine could rev that high. The power at 5k rpm is 300*5000/5252=286hp. The power at 17k rpm is 200*17000/5252=647hp!! The trick is reaching 17k rpm (think about a 2.0 liter V12 motor with low reciprocating mass and HEFTY rods). In this case, you're pumping out 2.26 times as much energy per second at 17k rpm than you are at 5k rpm. That'll get you there faster! A lot of power comes from trying to keep the torque numbers good into higher rpm ranges and even in raising the redline.
So that's my piece. Whoever decided to call it "torque" messed up in my opinion. That word was already being used for something completely different, and all it's done is confuse people.
Alright, I'll try to do a better job of explaining what I was saying earlier. As for the example with the torque applied to the bolt, I was just confirming your statement about torque being equal to work done per revolution through a derivation based on the power-torque relationship. You calculated work done on the bolt to be 157 ft-lbs, which works out to be 628 ft-lbs per revolution. The torque applied during the process is just the value of work per revolution divided by 2*pi. The reason torque and energy have the same units lies behind the fact that angular displacements (radians) are necessarily treated as dimensionless quantities in calculations. You can convince yourself that rotational work = torque X angular displacement, just as translational work was equal to force X distance.
Torque IS the work done per revolution of the engine, just as force is the work done per unit distance.
I got it now!
But torque is actually the work done per radian rather than per revolution of the engine, which is consistent with force being the work per unit length. Right? If so, my text book was off a little bit saying it was per revolution. Applying 100ft-lb of torque to a bolt will produce 628ft-lb of work per revolution, but it will produce 100ft-lb of work per radian. If the bolt doesn't move, that's zero radians, so zero work is done.
So the torque in a dyno chart is actually the same thing as the twisting force at the flywheel or wheels after all.
Don, thanks A BUNCH! I see the light - FINALLY.:rocks:
Your welcome, Mack. I'm glad I was able to help. For the units to work out properly, you're right that torque is equal to work done per radian. It's ok to call it work per revolution, but you have to understand that for the units to make sense, you need to introduce a constant of 2 pi in the equation.
