Disconnecting Stock Alarm
Piper
May 1, 2004
Chaska, Minnesota
I just got my 95 GST on Friday. It has the stock alarm system as well as a sidewinder aftermarket alarm system. The two always are setting each other off and I was wondering how to disconnect the stock alarm system. Thanks.
There is no easy way to disconnect the factory alarm.
Inside the drivers door, there is a wire coming from the key cylinder(it will show ground when you turn the key to unlock position).Go to Radio Shack buy 2 1n4001 diodes, the have a silver band on one side, connect the sides with the band together.Find the unlock wire coming from the alarm(green or blue on the sidewinder I can't remember).Connect the banded sides of the diodes to the sidewinders unlock wire.One of the unbanded sides then goes to the wire coming from the drivers door key cylinder, and the other goes to the vehicles unlock wire.This will disarm your factory alarm anytime you disarm the sidewinder.
The guy who owned it before me said he did that. What happens is when I lock the doors from the switch on the door panel the stock alarm activates. So when I use the sidewinder wireless pad to unlock the doors the car thinks someone is trying to break in because the stock alarm does not recognize it as a source and the alarm goes off. I have to unlock it with a key. I want to completely remove the stock alarm so nothing is left of it.
