Disabling A/c Compressor?
mtwollet
180
Aug 7, 2004
I recently discovered that my a/c compressor is bad I was wondering to disable it would all I have to do is cut the compressor belt and disconnect the electrical connector to the compressor, or just disconnect the electrical connector (because cutting the belt off sounds scary.) don't want to cut the beltie OMG but if its better to remove the belt I'll slice that puppy off since that belts only connected to the crankshaft pulley and a/c compressor :laser: :talon:
unplug either the compressor or the triple pressure switch, or pull the compressor relay to disable the AC.
cutting off the compressor belt is OK too.
    • Sdcryan1
