scrcco
- 39
- 2
- Jun 10, 2002
Bowie,
Maryland
I just installed a different head after my timing belt went. Everything is back together and the break-in period is over. Last night i revved past 5,000 rpm. for the first time and noticed it was struggling, I let off at 5,500. Then a riced-out Honda cruised by so i stepped on it, went to about 6,000 rpm's, now theres a huge cloud of smoke behind my car. I opened the hood to notice my dipstick shot up, and oil sprayed all over the underneath of my hood, then dripped all over the motor and exhaust. What could be the problem? I already replaced the PCV valve and does the same thing???
That old fart already gets enough praise.
), not taking your physcian's call doesn't mean you're cured, you're simply passing on the excessive crankcase pressure to others such as internal seals, gaskets, valves seals, turbo seal......etc. Unless a compression/leakdown test clearly points to excessive blowby (poor ring seal), I'm willing to bet most of you having this problem have either your PCV, breather or both vented to the atmosphere instead of properly re-routed back to their respective stock locations, intake manifold and intake pipe.
That's good though as this is still a very misunderstood topic and clearly there are alot of guys reading this who have modified their setups and are not getting proper crankcase ventilation.
