2G Different turn signal wiring
GSXvsTSI
147
14
Aug 11, 2015
Pleasant Grove, Utah
I rewired my whole car and I'm all finished besides the turn signal relay box. For some reason mine doesn't match up with any of the wiring diagrams. I know there is a 3pin relay for the talon and a 10pin for the eclipse(which mine is) but the colors and wire locations are different. Any help? 98 GSX
This is what I have from my Haynes Manual ….The book covers 1995 to 2005 Eclipse and Eagle Talon
Here is a 95 GSX essentially the 2ga version
97 gsx diagrams basically the 2gb diagrams
In diagram 1 depiction of connector "B18" gives pin designations for flasher module in diagram 2
Thanks. I like those graphs. But my plug I posted is different than all of those(for example, the right turn wire from the column to the flasher unit goes into #8. I don't have anything in #8). Any ideas?
I`m not trying to be a pest but please take a look at these pictures again … You posted a MB943259 Hazard Warning Switch and I believe this is correct . I may be wrong
Follow the A B C D arrows down too see where they hook up ...
Widgmastery you're all good, we're just trying to figure this out. Thanks for chiming in.
I was thinking that box is the turn signal and hazard flashing unit. I thought the hazard warning switch was the button(why there is a light in the diagram). However maybe I have the plugs wrong. Maybe I have the hazard button plug in the flashing unit. I'll check tomorrow.[/QUOTE]
So the answer is for some reason they used the same plug for the hazard button and flasher unit. So I had them plugged into the wrong things. Hopefully this will help some other people. Thanks for the comments.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
