Trav83
- 1,936
- 9
- Mar 10, 2009
Binghamton,
New York
Why are these CAS's different?
must have moved a little bit when I was tightening the bolts. Why would you need to pull the intake?? Point timing light at crank and read timing, loosen cas and rotate a TINY bit, read timing again. Repeat until it's where you want it, then tighten bolts down.
I guess if I really wanted to I could just get rid of the bracket.
