Difference in Automatic and M/T Radiators?
VegasTSI
101
Oct 29, 2005
Las Vegas, Nevada
On 2g dsm's is there a difference between the auto and m/t radiators? I have been looking for a "performance" radiator because my crappy stock plastic outlet/inlet's are wearing away. I have seen some companys say m/t only and others don't mention it. Is there actually a difference? And if there is a difference what is it?
A/T radiators have a transmission fluid cooler built into them. You can use an A/T radiator in an M/T by simply not connecting anything to the transmission cooler. You cannot use an M/T radiator in an A/T car because you won't have any way to cool your transmission fluid.
As stated above by my fellow wiseman:thumb: there are 2 different rads. An external trans cooler is a common upgrade with automatic transmissions and your car will actually run cooler by not having to cool that trans fluid as well as the coolant. I use my trans cooler ports on my rad as my power steering cooler because I had an auto in my car and swapped. It just makes a cleaner install with the FMIC no more bent up pipe zip tied in the front.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
