Resolved Difference between PCM and ECU?
hgould521
47
Jan 25, 2011
Hot Springs, South Dakota
ok so is there a difference between the ecu and the pcm? probably a dumb question but i dont know the answer.
also will a 97 pcm work in a 95?
oh and how do i tell if my car is eprom or not? its a 95 gs-t w/ at tranny
Solution
The PCM is used only on the 2g 420A (chrysler) engine where an ECU is used on all other DSM engines. You cannot use an ECU on a 420A or a PCM on non 420A's. The wiring harnesses are completely different. You can sometimes switch some ECU years with other ECU years depending on the year and generation (and some PCM years with others depending).
Solution
