1G Difference between manual and auto GSX
Erix
86
Apr 1, 2004
Vermilion, Ohio
I'm thinking about getting a 91 GSX and I'm not sure weather it has a auto or manual in it, so i was wondering what the difference in the two cars? I heard different size turbo and if it is auto could I swap a manual in it easy or is there other things need to do so?
1g auto has 13g, matching exhaust manifold, matching oil feed line, 390 injectors, ECU to control the 390 injectors, auto cams, and of course the auto. The 5 spd has a 14b, 450cc injectors, and ECU to match. And of course the other things I mentioned are different also.
so all i need to do is to find a wrecked gsx and get manual cams ,the 5speed tranny, ecu ,injectors manifold, 14b, and oil feed lines?or i could just upgrade the turbo to a t3/t4 turbo and that'd work to?
oh i heard there was some other stuff you have to do to like somethign witht he drive shaft??
