did some research.. still have a few questions about o2 dump..
highintenzity4
221
Apr 30, 2004
Mission, Texas
Would you guys recomend it for an internally gated 60-1 with cut exhaust housing? Can I get a 02 dump since I have cut exhaust housing?
I assume you have a pte with the divider cut on the turbine housing? You can not run a dump with the divider cut. I run just a tubular o2 housing on mine and have no creep issues what so ever. Besides, Im sure an o2 dump will get on your nerves after a while.
Yes sir I have the pte turbo with cut exhaust housing.. So for sure I cant use an o2 dump?
The only way you can run a dump is if you have the divider welded up. Without doing so, it will just be a constant exhaust leak.
