1G Questions about O2 housing with atmosphere dump
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
I was thinkin to buy the punishment racing o2 housing with dumptube just wanted to know if anybody is using it and does it help with boost creep? better then recirculated? better spool up? will the dumptube be long enough so it dont melt anything and stay out the engine bay or i would have to make a longer pipe?
i dont have a wastegate so would it still be ok to use this o2 with the dumptube cause i see alot of people have it but also have a some kind of wastegate like tial to? do i need a wastegate?
If you have boost creep it's best to address the issue of why it's creeping than trying to cover it up. Say by porting the wastegate outlet if it's a 16g for instance.
A dumped wastegate will have lower back pressure build up in the exhaust which will help with creep issues and make a difference in a high HP build. However if you don't want the sound then just get a recirculated o2.
If the pipe is routed low enough it won't create any discoloration in the engine bay as it only dumps on WOT.
If you want a recirculated external wastegate o2 housing then it would have a provision for the TiAL like you stated and you would remove the actuator from said internal gated turbo. Overall it's more of a personal preference if you want the sound or not and if you have visual emissions inspections as you would be dumping unfiltered exhaust.
