need advice and have a few questions
tsi2fly1991
40
Dec 21, 2003
scottsbluff.ne, Nebraska
HI I have a few questions about my set up my mods are
jdm engine buschur 2.5 downpipe, 3 catback exhuast , 2.5'' testpipe sbr ported manifold, tial 38mm wastegate ,walbro 255 fuel pump, RC 750cc injectors ,maft blow tru set up, dsmlink,buschur ported 20g turbo, greddy profec b boost controller,front mount intercooler , 2.5'' intercooler piping k&n air filter,blitz bov,apexi boost & egt gauge
My Question is What other mods do i need to get a good tune
and what kind of whp can a jdm engine produce
my other question is what kind of boost level can a stock jdm engine handle on a good tune
I know you can be right on the money but just a estiment of what i can get out my set up on pump gas is all im after any info would help alot
Thanks jeremy
The question is "What are your goals powerwise?". The stock internals can handle quite a bit of power. As far a tuning, I suggest DSMLink. I have it and love it. Do some research on the link, you will sway that way as well, I'm sure.:thumb:
Thanks jeremy
I cannot quote you on HP because the best way to do that is to get it dyno tuned. However I can answer your other questions. The things you have now will work great for tuning. You have a very good setup. A stock motor can hold well over 425 horse. However it is wise to upgrade the internals after this because they will not hold that power for a great deal of time. With your set up you should be able to run about 18-20lbs on the street with pump gas safely. Even more with a fine tune. Hope this helps. :thumb:
do you guys think i should get a fuel pressure regulater ? or any other parts before i take and get it tuned also i was wondering about jdm motor compression ratio Is it 7:8:1 or 8:5:1 you guys are always a great help
thanks jeremy ;)
Yes an AFPR is needed. I see you have DSMlink. You have a well balanced set-up. Try a JM SMIM as they are great and a set of cams to really make some power and shift at 7500 with these additions. I got the Crower 415's and replaced my HKS 272's for big gains to match the JM SMIM. www.jmfabrications.com
mark
