Did a boost leak test last night...
beatshack
199
4
May 19, 2005
Edmonton,
Well my car has had this strange steam-whistle sound. (you can hear it when it boosts here: http://www.beatshack.com/exhaustvid.avi )
After finally getting off my ass I did a boost leak test, and found a massive boost leak right at the turbo outlet gasket. Couldn't even pressurize the intake system to 1 psi using a bike pump. I used gasket maker as a temporary fix, and seriously the car feels like a new car. I'm now hitting 10psi at 2500 rpm instead of 3500 rpm in a 3rd gear pull. Also between shifts it hits 10psi again very quickly where as before it would take a few seconds... my turbo has been working double-time just to get me up to boost (poor turbo).
So to everyone who hasn't done a boost leak test yet, just do one, its worth it. :thumb:
Question is, how much were you able to pressurize the system after you fix that leak? My guess is you didn't retest........ if only it was that easy. OMG
Up to 15 psi, but it did slowly fall.. but slowly enough that I couldn't audibly hear any leaks. Even if there is leaks, hitting 17 psi at 3000 rpm is pretty good :)
Poor turbo. :toobad:
Not bad for a bike pump as long as those numbers aren't inflated. Since you're boosting 17psi, I would go back and test the system up to 20psi, this time use soapy water.
hahah yeah poor turbo.. good thing 14b's are very easy to come by and cheap around here. I'll upgrade to an evo3 16g when i blow this one, so i can finally install my fuel upgrades.
p.s. i did use soapy water in the previous tests, but only on areas where i could hear hiss.. i also recently backed down the boost to 15psi.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
