devcon liquid aluminum
yeti-gvr4
422
Dec 23, 2010
san diego, California
I just saw an add for this saying its the next best thing to sleeving a block.
I've done a bit pf research and found very good results and very bad results.
Anyone ever do this on a 4g63.
I could only find honda blocks doing this so far.
I am in no means attempting this. At least untill I build my second block.
Just looking for advice.
I myself think its a crazxy idea but honda owners boost to about 25psi with this in their blocks.
Just to make it sronger?
I don't know just an alternative to sleeving a block....
Why would you sleeve a cast iron, closed deck block?
Apparently I have no idea what I'm talking about is their a difference in honda blocks, are the open deck?
Sorry for the questions could someone give me a link to more info on why there's no reason to do this.
Would a sleeve effect a crack in the cylinder wall
Can you sleeve a 4g63?
Stock Honda Block
Stock 4g63 Block
The only thing I could see that it would be good for assuming it's what I'm thinkig is a block filler. There is that cement filler to strengthen the block that is poured into the coolant passages. Not sure if thisnwould be a light weigt alternative or if would even work well for that application.
WOAH that was a big difference
Is a v8 a closed deck block?
And what's the reason for the open deck on the honda block?
There are open and closed deck v8's, not all engines are made the same/equal....
I don't really know much about honda engines but maybe for better cooling, cheaper the way they made the blocks? I'm not exactly sure on that.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
