SonySlave
- 967
- 75
- Jun 24, 2004
Pasadena,
Maryland
I want to make this clear now, this is NOT another thread about relocating the engine fuse box or removing extra plugs on the engine wiring harness. There are plenty of those threads but very few, if any, threads about the chassis harnesses.
So, my car has always been a bit of an electrical nightmare. Half of my auxilliary gauges don't work (gas and oil pressure) and I barely street drive my car anymore. The car is 98% drag car and I'm tired of having all of the unnecessary wiring in my car. I've determined that I want to eliminate the front and rear chassis harnesses and put only the bare essentials on my own relays and switches, like the headlights, taillights, and radiator/trans cooler fans. I've even considered removing the stock gauge cluster in favor of my own Autometer gauge set.
The issue, as with most people, is that I'm not much of a wiring guy. I've gone through the service manuals and I believe that I know what I want to remove but I'm simply terrified of removing anything for fear of having something else seemingly unrelated stop working. I've already relocated the battery to the rear so the factory alternator wires are gone. I'm going to go through each of the harnesses from the service manual with individual questions:
A Harness (Front Chassis):
Above, boxed in red, is what I'd like to remove. Essentially, it's the entire harness in front of the motor. I'd like to unplug the harness from the under-dash fuse box and de-pin the other side from the under-hood fuse box. A13-A22 are already gone since I removed the A/C and emission years ago but the empty plugs are just sitting there. Will my plan work without causing issues?
E Harness (Rear Chassis):
Here, the only things I'm currently using on this harness is the taillights, reverse lights, and brake lights. The fuel pump is re-wired, the stock auto seat belts have been gone for years, and the power windows have always been wonky. I'd love to just unplug this entire harness from the under-dash fuse box and wire the brake and taillights with my own relays and switches. Will I have any issues with this?
D Harness (Stock Gauge Cluster):
I'm not entirely sure if I want to do this yet, but if I wanted to build my own custom gauge cluster, would I be able to remove this harness (including the gauge cluster) without any issues?
If anyone could answer my questions, I'd be ever so greatful! I don't have the electrical knowledge to understand the circuit diagrams in the service manuals to answer these questions. Thoughts anyone?
