2G Dejon intake pipe
Kpro22
73
Jul 15, 2016
San Diego, California
I just picked up a 2g dejon intake pipe and it dose not have any nipples for the valve cover vent hose, charcoal canister hose, and BCS hose). Is it ok to run with out it?
Without a vehicle profile, it is hard to provide specific advice..................
The easy way to solve this issue would be to drill, tap, and install some barbed fittings. Hopefully, you have a recirculating intake pipe if you are not running speed density (MAF).
  • I would recommend keeping the crank case vent routed to the intake (even better routed with an in-line sealed catch-can.
  • If you still have emissions equipment or have emissions testing where you live, keep it.
  • You could eliminate the BCS line so long as you replace the stock BCS with a non-bleeder type of boost controller (MBC or EBC).
