datalogger, maf, maf trans...
Boosted90GST
216
Dec 22, 2004
West Hazleton, Pennsylvania
aight, well i have all of those 3 list in the topic im pretty sure the pda is equipt with dsmlink already if not i'll get it, anyway the shop i have my car at doesn't have a dyno.. this guys tellin me he doesn't need a dyno to tune it in for me and i think otherwise. so i figured id just let him dial it in and drive it to this other shop about n' hour or so away that has a dyno and have it tuned in correctly.. problem is i'm worried it's not going too be tuned or running well enough to make it to this shop and i dont want anything to happen.. this is a freshly built motor with no miles on it so it needs 2 be broken in, i figured id just run around 10psi and keep it chill.. altho im still worried anyone have any sugguestins to this issue? or even the route i'm going ie: data, maf, maft..
I suspect your going to have a hard time tuning for the 860cc injectors shown in your profile with only a MAFT you would need a custom chip or DSMLink in your ECU. DSMLink on the PDA doesn't do anything unless you have the DSMLink in your EPROM ECU too. It won't even datalog a standard ECU.
If you have a chip or DSMLink you can get a good enough tune on your own to break the car in and be safe without have to run right to the dyno.
Steve
i do have the eprom ecu, and it's socketed n' chipped also. so i will just tune in with the dsmlink then.. i have too find my cd that came with the logger and make sure it's the correct software if not i'm sure i could get a copy.. do you think id be better off sayin #### the dsmlink and going with safc-2? and as far as the 860's go i upgraded again to 1200's... if it comes down to it i'll go with n' e-management system just to get it over with.. what do you think is the best solution?
I'm really confused. You can't use Dsmlink software unless you have Dsmlink. You can't compensate for 880's or 1200 via Safc2 or MAFT. You can if you have a keydriver burnt to your injector size and fine tune LTFT's and enrichment vlaues via SAFC2. What exactly do you have....
