dash gauge pod
sexystover
202
Nov 6, 2008
allentown, New Jersey
so i came up with an idea, on a 1g to the left of the cluster there is a panel that comes off the dash with a screw and then clips in, i want to turn that into a 2 gauge pod but not sure thebest way to do it, any suggestion? does anyone make this sort of thing?
The best looking route, maybe not easiest, would be to fiberglass in some gauge pods. However you could also get some standing gauge pods that mount in adjustable stands and leave the gauge wiring exposed if you aren't looking for aesthetics. Personally that exact spot is a wierd angle to get a set of pods to look just right in fiberglass. Why not go with an actual pillar pod?
I did actually fiberglass in a pod in that location a number of years ago. I had my boost gauge there and while it was functional and looked good, I can't honestly say more than 1 gauge would fit there. Its too tight and if you do get 2 in there, the angle is all goofy and I doubt you'd be able to see them properly.
ill have to take a picture, i currently have 2 gauges "rigged" to fit there, with just holes cut and sort of stuck there, i like the angle they are on for the most part and the reason i would prefer that over a pillar pod is because other then the 3inch exhaust and front mount my car looks stock and having a pillar setup would easily give it away that its modded, but where they are at now, people and more importantly cops cant see them so it maks me less of a target
