dash electrical connector help
Kyle_T
795
14
Oct 19, 2008
Muskego, Wisconsin
I took out my dash to dye it black, but now I got it back in the car and im connecting everything back together, theres this electrical connecter on the passenger side right by the glove box that i cant find where it connects to, heres pics of it
I may be just stupid, but i tried looking around everywhere and feeling around where the connector comes out but cant seem to find where it connects to :hmm:
So does anybody know?
anyone?
I can get better pictures if that helps
Try a few different things on your car and see what doesn't work. For example, try to start it, try all lights, try power mirrors, etc. That may help you narrow it down.
The only connector on that side is for your speaker and the light for the glove box.
Try taking the glove box out to see where the wire is coming from. That style connector is more or less located on the driver side a d center console under the radio.
Was everything plugged in that you visually saw putting the dash back on? Aftermarket alarm system at all?
I don't have a connector like that.
Only real electronic thing on that side of the dash with a plug like that is the Cruise Control ECU but on my 96 the connector is yellow.
its the inside body harness... connects the inside wiring harness and i believe the door harness to the main harness
I found out that it was for the abs ecu, and my car doesnt have abs so i guess the plug just goes to nothing.
thanks for the help though
