Cylinder Wall Advice
Splitpi
1,204
28
Sep 13, 2005
Des Moines, Iowa
I'm looking into buying a "rebuilt" short block with ~3K miles on it before being torn apart due to timing belt failure, and I have no reason to believe the seller is less than genuine. However, looking at the cyclinder walls, I am concerned by odd wair marks on #1 & #4. Is this normal? A concern?
I have had some friends say its ok, others say bore the cylinder and rehone it. Oppinions please.
Edit: looking at the photos some more, it appears to just be cylinder 1, and the slight blemish on 2... not 4.
Yeah thats definatly not good. You're gonna have to pull the slugs out, hope like hell they aren't scored up too bad and rehone the block to get rid of those marks. Basically it looks like the ring was installed improperly and gouged the block.
Sorry man but dont buy it.
Yea I agree I would not run it that way let alone buy it. Looks like something got in a ring land and mard the wall real good. If you buy it get it professionally torque plate honed cant really tell how deep it is but should be able to hone out if you cant feel it. If you can feel it find something that needs no work. If it were me I would pass on it and find a motor in better condition. You will be putting alot of money in this block to make it right its not worth it.
