Cyl 2 misfire after timing table swap.
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
I fixed an exhaust manifold leak, and while in the process I converted to the evo stock timing table. I fixed everything, and I kind of had forgotten I had swapped tables. I was cruising around the neighborhood and did a few 80% throttle runs and all of a sudden everything started clunking. Very low idle, thud thud thud from engline. Sounds like its the tune, and I cant revert back to stock for some reason. HELP!
Edit : I found a thread where I posted a log. Going to use that and revert everything back. Will update if this fixes my issue, I doubt it though.
